Home > Technical (L405) > Steering wheel buttons stopped working |
basil Member Since: 09 Dec 2014 Location: UK Posts: 88 |
I had the same issue with my volume up and down (RR AB 2014) and ask the dealer to replace the switch - They refitted the existing one and it sorted it for around two months, now its starting to go again. |
23rd Oct 2019 10:01pm |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 |
probably clock spring. |
27th Oct 2019 12:31am |
Apologies if I am being thick, but I have no idea what CLOCK SPRING means? |
27th Oct 2019 10:54pm |
it is the thing on your steering column and behind your steering wheel that allows connectivity between the cars electronics and the controls on the steering wheel/horn/air bags/heated wheel/ etc etc etc. When one goes bad certain functions will go on and off, it could be as easy as removing and giving a good clean, or it may need replacement.
28th Oct 2019 1:56am |
Thanks for explaining. |
28th Oct 2019 2:23am |
