Home > Maintenance & Mods (L322) > L322 3.6 tdv8 oil leak
seany150
United Kingdom 2006 Range Rover Vogue SE TDV8 Buckingham Blue
Hi just going over the motor as the mot next week and spotted this leaking.
Typical there always seems to be something on this car
Is this a simple fix, anyone had to do the same? Cars 2007 3.6l
Any help much appreciated
Cheers
Sean
Post #532441 28th Oct 2019 2:20pm
DrRob
Could be a number of things. Some on here trying to find leak sources 12 months in! Banging Head Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #532442 28th Oct 2019 2:24pm
seany150
It's definitely coming from this shaft, I cleaned it all up. Moved car forwards and backwards and checked again and it was wet again so leaking out on rotation. I'm hoping someone may have had same issue and can tell me it's a simple 10 min fix
Probably wishful thinking though, everything seems difficult on this car Sad
Post #532470 28th Oct 2019 5:07pm
DrRob
Take it to Evans Garage up the road from you. Highly rated. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #532482 28th Oct 2019 6:24pm
seany150
so the car passed the mot yesterday, got an advisory on this oil leak so keen to have a go myself now I'm not rushing to get it done to mot deadline. has anyone any firsthand experience how to go about, how complicated is it?
its definitely coming out from this driveshaft as i can clean it off, start the car and move back and forth and its leaking again
any help much appreciated
Post #533633 9th Nov 2019 5:03pm
DrRob
First photo looks like oil higher up... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #533641 9th Nov 2019 5:45pm
Nick591
If its leaking down the bell housing it may be coming off the V between the cylinders which indicates a problem possibly with the oil filter housing/fuel cooler assembly. Mine has had this leak for over a year but the leak on mine is really small so I haven't got round to fixing it. Its a relatively big job to get at the assembly to inspect or replace. On mine it doesn't drop oil when parked and fortunately doesn't leak onto the exhaust or the driveshaft. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #533705 10th Nov 2019 1:52pm
