![]() | Home > General (L405) > My Sept 2014 AB vs my father in laws June 2015 Vogue |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8093 ![]() ![]() ![]() |
Do they have the same size wheels ?
BigladUK Member Since: 04 Oct 2014 Location: Milton Keynes Posts: 106 ![]() ![]() ![]() |
Actually they don't, they are both 22in but different styles
If they are both 22's the brand shouldn't make too much difference, but it's possible - my wife can tell when I've switched from summer to winter continentals - both 22's
I run mine at the lower number ( you know there is 4 people in the car or 27 people ), I wonder if they need more air then. I can try that |
Maybe just check what your FiL has his at ?
Great,
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
I have a 63 plate one, higher miles circa 85k and its tight as a drum. Suspension components are the normal places to start. |
Thanks, the wierd thing is I was happy enough until I drove his car , I might have the dealer drive both cars back to back
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
4 wheel alignment makes a big difference in handling - a good sign if it’s out is if the tyres are wearing unevenly 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
His car will have the improved EAS block with twin valves, the updated ARB complete with harmonic balance weights! etc etc...
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
What struck me was your girlfriend has been in your father in laws car !!!!! Are you a danger freak or suicidal, what if your wife ( his daughter) finds out |
Thanks all for your help
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
Mine has had the new ARC valve Block and balancer and new bushes all round and can't say I noticed THAT much difference in road holding etc. The only things that I noticed was that a) the awful front clunking noise had now finally been fixed but has been replaced by b) a god awful hydraulic hissing sound from under the car where the ARC block sits, when the car is at idle at traffic lights for example. ![]() When I did notice a difference once was when I got a 6 month old courtesy AB while mine was in for repair, now that difference was chalk and cheese. Getting mine back felt like I was driving a jelly. When I spoke to the master Tech he said there had been significant suspension revisions between mine and a 2019 spec. ![]() |
