Home > Technical (L322) > 4.4l v8 diesel starter motor not working
dazza1983
not sure if im missing something but the fact it starts your old motor and not your new one seems to indicate that the battery or wire is not at fault..
Unless of course your new starter motor is bigger meaning it needs more power to start?
Do you have a way of testing the new strater outside of the car?
seems strange that you old one tries to work
maybe this can help?
https://www.wikihow.com/Test-a-Car-Starter Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #532735 31st Oct 2019 11:48am
GraemeS
Australia
The solenoid on the new starter isn't operating via the wire from the relay but did when jumper leads were used, indicating that the new solenoid must be requiring more current than the original to operate but the resistance in the wire is too great to provide the required current (the high resistance section will be getting hot!). As original starters have been burning their solenoid contacts, it is not surprising that a later version starter is fitted with a heavier duty solenoid so that the contacts aren't so readily burnt.
Post #532742 31st Oct 2019 12:15pm
ozzy22
Scotland 2012 Range Rover Vogue TDV8 Stornoway Grey
Thanks Dazza,
Yeah the fact it starts the old and not the new has had me scratching my head!
I’ve tested the new starter out of the car no problems and also now in the car. I took the ignition wire off and ran a direct feed to the battery. The starter turned over no problems when I did this. Like Graeme said, the new one must need more power for it to operate the solenoid.
Im low on time at the moment but hope to be able to run the new wire from the starter relay by the end of the weekend. I think I’ll just replace the starter too while I’m there doing the wire as it has done 55,000 miles on that starter. Going up into the Highlands this winter so don’t want to risk getting stuck.
Post #532743 31st Oct 2019 12:18pm
ozzy22
GraemeS wrote:
The wiring schematic shows for the wire run:
starter solenoid
2.5mm2 2870mm
connector
2.5mm2 1165mm
solder joint
4.0mm2 1165mm
connector
4.0mm2 855mm
relay
No wonder there's significant voltage drop under load.
A 4.0mm2 direct replacement might only be 2m long.
Graeme,
Probably a silly question.....
Do you happen to know if the wire at the starter relay is the same colour as where it attaches to the starter motor or does it change somewhere along the multitude of joins?
Cheers Oz
Post #532744 31st Oct 2019 12:29pm
GraemeS
Australia
White with purple stripe (WP) at the starter but then red (R) the rest of the way to the relay.
Post #532798 31st Oct 2019 8:47pm
ozzy22
Thanks mate! Helps me a lot! Very Happy Oz
Post #532799 31st Oct 2019 8:58pm
GraemeS
Australia
[/img]
Post #532800 31st Oct 2019 9:14pm
