Home > Maintenance & Mods (L405) > Service and warranty work |
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 |
it lowering and then shooting up would be either it thinks there is some type of obstruction (tho I think you should see that on the message center). Or the exhaust silencer near the compressor (pretty sure the l405 has this) is clogged up. When the silencer on my l322 clogged it'd do the same thing. You'd command it to lower, it'd try, then shoot up to off road. |
31st Oct 2019 2:58pm |
Brunel Member Since: 10 Apr 2019 Location: Bristol Posts: 128 |
I had the identical suspension issue recently. They changed the compressor under warranty and now it’s fine. Don’t know what else they did, as I didn’t see how a compressor change on its own could fix it. Anyway it works
31st Oct 2019 3:16pm |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
not applicable as the problem was flagged to the dealer whilst still in manufacture warranty so it will still be covered until the problems are fixed. any NEW problems of course will then be Car Care plan ( LR extended warranty) on the assumption it was bought. |
31st Oct 2019 5:57pm |
Statler Member Since: 22 Jun 2019 Location: Leeds Posts: 29 |
Thanks for the replies gents, they’re adamant they’ve resolved it.
31st Oct 2019 9:21pm |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
There's probably not an issue with the FBH but more likely an issue with either the battery or whatever your car believes the state of the battery is. I've had this problem, changed the battery and all seems ok to date. That said, i've put the old RR battery on a 4.5 litre agricultural machine with no glow plugs, which is normally a bitch to start and it fires up no problem. Maybe these cars are super sensitive to voltage, but unfortunately you can't argue with what the car thinks. |
31st Oct 2019 9:45pm |
Thanks, as the warranty is out at the end of Nov I’d rather get the batteries changed under that warranty.
31st Oct 2019 9:47pm |
have they checked nothing is draining the battery ?
1st Nov 2019 4:29pm |
Thanks for the replies,
3rd Nov 2019 10:02am |
