![]() | Home > Technical (L322) > oil in intercooler pipe |
iancollins Member Since: 17 Mar 2010 Location: milton keynes Posts: 264 ![]() ![]() ![]() |
just noticed when checking fluid levels this weekend that there was oily deposits around both ends of the pipe that goes from the intercoller pipes (both sides) to the turbo..
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
if its only a little oil then its probably from the crankcase breather, if it was runny and you had a lot there then it would be worn bearings in the turbo...a little mucky oil deposit is normal.. ... - .- -.
thanks for the response..
i'd still keep an eye on it though ian... ... - .- -.
thanks for your reply.....
