Home > Technical (L322) > Shudder from Transmission
Alex 111s
Scotland 2003 Range Rover HSE Td6 Zermatt Silver
Hi All,
My 53 plate TD6 with 71k miles has developed a shudder from the transmission. it hapens when you ease up to a slow rest or are gently pulling away. (doesn't occur when pulling away with a bit of revs)
is this a comon symptom?
there doesn't seem to be any guidance on changing transmission fluid at the service intervals - what's best practice to follow?
thanks
Alex
Post #53267 7th Mar 2011 10:22am
drive shafts or front diff, have you had yours done under warranty.. ... - .- -.
Post #53268 7th Mar 2011 10:29am
dan_uk_1984
Re: Shudder from Transmission
thanks
Alex
This topic has been covered a fair few times, there is a detailed "how to" here somewhere. The GM box requires a fluid change every 50K - LR say the box is sealed for life - this is the life of the warranty. I've covered this various times in the past, recently here:
http://www.fullfatrr.com/forum/topic4805.h...oil+change
If you do the change yourself make sure you use genuine parts and exactly the correct fluid (listed in the WiKi). Don't take it to a Land Rover dealer, they wont do it, don't take it to a LR Indy because more than likely they won't have ever done one and the oil levels is a PITA to get right. Search yellow pages for a gearbox specialist as they will have worked on your box or variants of. The danger is that someone who doesn't know what they are doing will short or over fill it and it will pop after 5K.
Expect to pay £125 - £175
Post #53274 7th Mar 2011 10:58am
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Better go in today then tomorrow, because it could happen any second
i had it three times, and ones it happend whilst doing 100mph on the moterway, and i can tell you, that didn't make my wife happy.
one time at home, and one time just 10minutes from home
you are one lucky person to get with a 2003 all to 2011, better not push you luck
Post #53311 7th Mar 2011 2:23pm
