Home > Technical (L322) > Earnt my stripes today - TDV8 4.4 Alternator replacement |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 332 |
Top man and good effort though - I applaud you - get into the hot bath but I bet you won’t wipe the smile off your face!
2nd Nov 2019 10:07pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
He who dares wins |
3rd Nov 2019 10:10am |
MAF260 Member Since: 02 Mar 2017 Location: Hertfordshire Posts: 25 |
My tensioner has failed so I'm here researching if it's a job I should attempt myself - I'm quite competent with DIY mechanical work and have a decent set of tools. I'll just be replacing the tensioner, idler pulley and belt, so not as involved as you with the alternator as well. Any hints/tips/pitfalls in doing this job please? Why did you need to jack the car up - was it to get to the alternator from below? I'm shorter than you and have a small selection of stools to help if necessary!
4th Nov 2019 11:09pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Tensioner: NorthernMonkeyJones did his and wrote a guide, have a look I think it's in the wiki Cheers, Greg
4th Nov 2019 11:35pm |
ffaffage Member Since: 12 Aug 2019 Location: Hampshire Posts: 19 |
To get access, you need to remove the fan. The fan won't come out without the shroud being removed (at least I couldn't find an angle that worked). The shroud is attached all the way around, including the bottom edge (and there is some pipework bolted to the bottom nearside corner, and another bolt head underneath that). To remove the lower bits, you need to take off the front half of the covers underneath, which means getting under it. If you are organised, you could do all the underneath work first, then drop the car down and do the top bits.
4th Nov 2019 11:48pm |
Thanks - I've found it and am having a thorough read.
