Home > Technical (L322) > Rear windows dropping
DavidS
Spain 2007 Range Rover Vogue SE TDV8 Java Black
Hi All, The rear windows seem to be disconnected from the mechanism and are slowly dropping, I have taken the door card off but can`t see what the problem is. Does anyone have an exploded diagram of the likely problem, or has solved this themselves? TIA David.
Post #533217 5th Nov 2019 12:38pm
theres a diagram of the front window mechanism in the WM, that might give you some ideas.... ... - .- -.
Post #533220 5th Nov 2019 12:50pm
rjff
May be you've checked, but does the window mechanism operate, even if only to hear it move and not operate the window? Does the window operate at all in any direction, partly or otherwise?
If so it could be the cable in the regulator is loose/damaged or snapped. They are handed for the doors so I don't expect you can swap to check. Cheers
Richard
Gap IIDBT
Post #533245 5th Nov 2019 7:17pm
DavidS
Thanks Stan, But that manual is the clunkiest thing to use ever, spent half an hour trying to get to the right page and gave up.
rjff, the motors run but nothing moves, not even a little.
Post #533326 6th Nov 2019 4:34pm
rjff
David
I can't be sure about this. but the manual for the 2010-2012 could have the same info as even JLR may not change the workings of the window gear every year. It's well sorted and could point you in the right direction.
If it runs and nothing moves, the chances are the regulator has a broken cable, I think Confused
Looks like a door card off to investigate I'm afraid. Cheers
Richard
Gap IIDBT
Post #533371 6th Nov 2019 11:30pm
PatrickG
United States 2008 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
On my ‘08 the plastic dammit snapped off that retains the cables and springs. I drilled and tapped some #6-32 holes then screws and washers to retain the cables.
I had to remove the inside plastic window trim, the outside window divider trim, the window, etc. to get the regulator out. Fun. The thing let go less than 24 hours after I brought the truck home. I was standing there next to it when it let go. Sounded like the window shattered. Ordered an eBay window before I dug in to it. It’s in the closet collecting dust.
Regards,
Pat G.
Post #533377 7th Nov 2019 2:46am
rjff
Excellent repair sir. Thumbs Up
Filed for when mine goes Cheers
Richard
Gap IIDBT
Post #533402 7th Nov 2019 11:30am
DavidS
Thanks all, well looks like pulling it apart is the only way.
Post #533518 8th Nov 2019 2:12pm
