Home > Technical (L322) > No Parking/hand brake on warning light (Newbie first R/R) |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Does it light up on the initial self test before starting the engine? |
13th Nov 2019 12:32pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
cant remember what mine did but i think its only the electronic handbrakes that have the 'P' icon lit up when the park brake is on... ... - .- -.
13th Nov 2019 12:38pm |
On The Edge Member Since: 11 Nov 2019 Location: LANFRECHFA Posts: 13 |
Yes it does light up on the self test for a couple of seconds but not when the handbrake is pulled up. |
13th Nov 2019 3:47pm |
Owners Handbook = Should light up when Handbrake applied or if there is a fault with the Handbrake system. |
13th Nov 2019 3:58pm |
Bulb is fine must be the hand brake switch end. On the passenger side of the lever is the switch hope it is this as there is no doubt several miles of wiring/connections/strange black boxes etc.. Check the switch as a first step. |
13th Nov 2019 4:17pm |
Thanks will remove console cover and gear Knob to see what I can find.
13th Nov 2019 5:34pm |
theres a WM link in the wiki that might help.. ... - .- -.
13th Nov 2019 5:35pm |
Thanks but whats a WM Linc ? |
13th Nov 2019 6:04pm |
Click on the WIKI link at the top of the page scroll down to brakes then handbrake WM = Workshop Manual
13th Nov 2019 6:10pm |
HI think I got it now - Workshop Manual
13th Nov 2019 6:11pm |
Finally had the time to take a look at Handbrake light switch - wire had broken off the copper connecter holder thingy managed to fix with a bit of improvisation and it now works again .
25th Nov 2019 10:42pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4231 |
2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Nov 2019 10:47pm |
