![]() | Home > Technical (L322) > Warning when cornering |
| alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349
My vehicle lurches to the left on a right hand bend and produces the warning Anti skid on a right hand corner. Has anyone had this please.
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 546
I would also check the steering angle sensor. 2016 Skoda Octavia VRS Estate
I have just had the GAP tool on it and there are no faults concerning brake or abs systems. I went to the steering sensor and it asked if The s/wheel was straight and I confirmed that. So maybe do a full left to right but that should have been asked surely. |
Steering done right to left, but unsure if that’s the cause .
Will check tomorrow, I am giving thought to the offside rear shock absorber as I said there is a lot of movement when you lift
The above would happen a day or two before the MOT . So its booked in tomorrow and I will be interested to see what has been picked up , I have my own ideas , so scouting the internet for parts at the moment. |
MOT Passed but with advisories, so front Lower (Front Arm Inner and Rear arm Inner worn , have been advised if I want to replace would be better with poly bushes . If I replaced the lot its looking like £165 and to replace the whole arms in a deal it would be around a £100 .
Does anyone know if there is a driveshaft extractor /puller for the Range Rover . I know that when I did the extraction and replacement of the shafts for the AbS REPAIRS , they were a pain in the butt using heavy hammers etc. |
A pass , but with advisories!
| Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193
People have found that replacing the standard LR front lower inner suspension bushes with poly ones dramatically increases noise, vibration and harshness of the ride. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
It’s standard arms that I am fitting, poly bushes are 65£ dearer and although I have a press it’s just not worth the hassle. I have noticed though that when I fitted a single arm last year I tightened it up while the suspension was still hanging which was wrong as I read Rave. Not only that the bolt was almost impossible to undo , it had tightened even further through strain!
