Home > Technical (L322) > Preparing to change battery
TimperleyRR
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
Dear Forum
I am preparing to change the battery on our 2006 TD6 L322 Vogue SE. I have read the wiki in detail but have also seen a number of tales of woe on the forum following other battery change attempts, mainly revolving around the need to reset various of the RR computers. So can I ask for some advice as to the painless way of getting this done?
In addition to following the wiki should I:
1. Touch the disconnected terminals together to reset the ECUs before fitting new battery?
2. Do I have to carry out the battery replacement reset in the “Body control menu” section of my iid?
3. Is there a way of getting the bonnet fully open past the standard 40 degrees to make it easier to get batteries in and out?
Post #532566 29th Oct 2019 6:32pm
It's in the wiki (top right under where it says fullfatrr.com)
Quick Link and this oneThumbs Up
Post #532567 29th Oct 2019 6:44pm
TimperleyRR
Thanks
So no need to reset anything afterwards with the iid tool then?
Post #532568 29th Oct 2019 7:11pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
not on a 2006, no ! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #532569 29th Oct 2019 7:16pm
TimperleyRR
Post #532570 29th Oct 2019 7:29pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
You may have to do the one-touch on the windows it may not be relevant on your year.
Post #532587 29th Oct 2019 9:49pm
TimperleyRR
Thank you all
Change done last weekend with no drama. Nothing needed to be reset on my 2006 model save turning the steering wheel a few times for headlight adjustment.
In addition to the links posted above I found some more which I would like to share as they gave me more confidence about tackling the job:
Putting bonnet into service position:
A picture may paint a thousand words but a video does it better:
Disconnect / reconnect instructions same as the wiki but with a helpful diagram as well:
http://metricrat.co.uk/disconnecting-the-b...ation-rhd/
Post #534560 17th Nov 2019 1:28pm
chris_stendall
United Kingdom 2009 Range Rover Autobiography TDV8 Santorini Black
So it would appear I have messed up! Didn't realise there was a procedure to replacing the battery and now the car wont start! Is it a case of needing the tool to inform battery change has been completed or am I in dire straits now?
Post #534839 19th Nov 2019 9:12pm
make sure that the battery is indeed fully charged and check all the connections and that you have connected all the wires..... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #534846 19th Nov 2019 10:05pm
