Home > Technical (L322) > help please asap
dazza1983
help please asap
hey peeps ive found where my smoke and diesel smell is coming from.. thing is i dont know what it is??
Its at the very rear of the engine underneath the pollen filter and you can see the silver insulation is covered in black..
 Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #534564 17th Nov 2019 1:46pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Often I can get a smell of unbutnt fumes through the vent , and if that mess is near the pollen filter then its something to do with the fuel burning heater if you have one.
Post #534565 17th Nov 2019 1:53pm
dazza1983
hey buddy its coming from the black mess in this pic not the fbh Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #534566 17th Nov 2019 1:55pm
Discotigger
Boost hoses?
Post #534608 17th Nov 2019 7:23pm
dazza1983
Found out its a egr tube, land rover crushed the flange and under hard throttle its was leaking to the point exhaust fumes were being sucked in via the HVAC and the heat from the engine was causing smoke .. lots of smoke Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #534612 17th Nov 2019 7:35pm
Discotigger
Ouch, hope you get it sorted, there's nowt worse than smoke in the cabin!
Post #534615 17th Nov 2019 7:46pm
GGDR
Where is that pic in the engine bay Daz?
. Cheers, Greg
Post #534619 17th Nov 2019 8:08pm
dazza1983
ITS the very rear of the engine mate, part now identified lol.. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #534675 18th Nov 2019 12:35pm
dazza1983
Land Rover agreed there technician crushed the flange of the pipe. So new one arrived today f.o.c and I fitted it myself. Pig to do becuase there is what looks like a high pressure rail or similar right about it and the heat proofing around the tube made it really hard to locate properly.
But she’s in now and my mpg has shot it bu around 10mpg and something I didn’t realise was that the leaking tube was making the engine noise much much louder. Very quiet and civilised now. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #534848 19th Nov 2019 10:10pm
stu
Blimey, if they Censored broke it they could fix it!! Lunatics.. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #534984 21st Nov 2019 7:57am
GGDR
Any more pics Daz?
Still trying to orient where your pic is taken from.
. Cheers, Greg
Post #534988 21st Nov 2019 8:27am
dazza1983
See if this helps Greg. It’s the very very rear of the engine.
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #535010 21st Nov 2019 12:40pm
GGDR
Nice one Daz Thumbs Up Cheers, Greg
Post #535012 21st Nov 2019 12:57pm
dazza1983
Are you suspecting problems with yours Greg? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #535014 21st Nov 2019 1:17pm
GGDR
Just going to check out that area / union - a bit of a diesel waft under the bonnet, not sure if normal.
Will check it many thanks for the additional pix Daz.
. Cheers, Greg
Post #535054 21st Nov 2019 8:34pm
