Home > Technical (L322) > Reduced engine performance
Page 2 of 3 <123>
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Your wiring may well still be reversed. The TSB on here will explain.
This engine is notoriously difficult to bleed so you may still have air in the system. The pump should start running as soon as you turn the ignition on. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #534099 13th Nov 2019 5:06pm
Danwilderspin
there's a bulletin on here which tells you the correct order of the pins i imagine its right.
Did you fill the top up with coolant and take out the bleed screw on the top hose of the new pump as well as the main bleed screw and hand pump/keep filling the reservoir until no bubbles? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534100 13th Nov 2019 5:08pm
Glibbs
Ah, I did look for a bleed screw on the pump to no avail but do you mean there's one on the hose itself? Range Rover 4.2 SC
2 Range Rover Classics - one from new but both rusty now.
Rover 3.5 Coupe had since new.
Subaru Legacy 3.0.
BMW K1200RS.
Post #534104 13th Nov 2019 5:26pm
Glibbs
Well I have coolant coming out of the bleed screw above the pump and no air bubbles showing in the coolant header tank. Still I get the message 'Reduced etc'. Ripping my hair out and there's much much of it anyway. . . I must be doing something wrong.
Should I bleed without the engine running but ignition on?
How long should I bleed it for?
Any clues pleased as I am covered in snow and soaking wet. Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #534221 14th Nov 2019 2:13pm
Danwilderspin
I don't know the official right answer to this but I know how the Bmw ones work and have followed that philosophy.
took out BOTH bkleed screws. then kept slowly adding coolant to the tank until it ran clear of both holes with no bubbles (involved a fair amount of over flowing and exploding back out the filler.) then squeezed the hoses all a few times and then repeated again until clear. I then tightened the screw above the pump hand pumped a few times put some more in then put the key in position two and could hereto caveatting so while on I pumped the inlet by hand and kept topping up the header tank and then hey presto caveatting stopped. then put the bleeds screw back in once no bubbles.
Seems really convoluted but seems to work for me an its probably massively overkill. Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534235 14th Nov 2019 3:47pm
Glibbs
I thank you - nothing is overkill after what I've been through. . .
I'll give it a try a little later.
Could there any other reason why the car would throw up this error do you think? Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #534236 14th Nov 2019 3:52pm
Danwilderspin
fuel pressure - I had it on mine recently when they did the log conversion they hadn't sorted the pressure properly at the time. Ironically it was fixed then the week after it was back but this time it was the pump been good since touch wood.
Maybe other things too? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534239 14th Nov 2019 4:36pm
Glibbs
Many thanks but I wouldn't a fuel pressure issue trigger an fault that the iid would display? Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #534315 15th Nov 2019 9:12am
Danwilderspin
well you'd think that but I had my fuel pressure hose off for a long time on mine and no fault (its the vacuum hose from the supercharger manifold to the switch with an electrical plug) check that's all on and not fell of?
How did the bleed go? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534356 15th Nov 2019 1:27pm
Glibbs
I just can't fix it. Been on it all afternoon. No air bubbles. No errors on iid but still "Reduced Engine etc". The engine cover off and I can't see anything untoward.
Any mobile mechanic available around the north Taunton to Tiverton area please? Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #534701 18th Nov 2019 4:33pm
Danwilderspin
you got any faults?
Do you have lpg?
have you access to live data? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534702 18th Nov 2019 5:26pm
Glibbs
Hi,
No faults (one for DVD player. . )
No LPG.
Yes to live data.
Just ordered a Mass Air Flow Meter cleaner - grasping at anything! Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #534703 18th Nov 2019 5:29pm
Glibbs
BTW the error comes up only after running the engine in the drive and then, after about 10mins to warm up, try to rev it and the error comes up after the engine is rough. `Revving to up about 2000 rpm for any length of time does not produce the error. Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #534705 18th Nov 2019 5:34pm
Danwilderspin
Have you0 confirmed wiring is correct way on pump? how long you been getting it? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534709 18th Nov 2019 6:27pm
Danwilderspin
Also side point but may help have you done your thermostat , and two coolant temp sensors as the coolant sensor can cause looking at the Manual like the maf Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534712 18th Nov 2019 6:38pm
Page 2 of 3 <123>
