![]() | Home > Technical (L322) > What should the battery voltage be when parked? |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
I’ve just checked my battery on the driveway and it’s 12.4v. I’m guessing this is why the FBH won’t turn on in the mornings?
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
Although I'm running a 4.4TDV8 the normal charging voltage is around 14.2 to 14.5 on mine depending on load. That said, the voltage at rest is about 12.4-12.7 in the mornings after reasonable runs. I've been using it for shorter runs the last 3 days and it's about 11.8 at rest in the morning. The FBH starts on remote and runs for about 10 minutes before cutting out. The FF starts fine at that. The WM says the FBH should run at less voltage and cut out at somewhere about 11V if you have a look.
Thanks.
I went out to the car this morning and the trickle charger was showing 15v.
Andy,
| TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 672
Battery wise when the engine is off the FBH low voltage limit is 11.4 V for more than 10 seconds; the system is re-enabled if battery voltage increases to 12.2 V.
I had a multimeter across the battery and activated the fbh and the voltage dropped to around 11.7. It whirred under the battery for around 30 seconds then stopped. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
where Are the pipes located? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Andy
Exactly this, remove the engine cover and you will find them passenger side running towards the control valves which are towards the front of the engine bay, from their they run back in the same way towards the heater matrix. Metal pipes, fairly easy to find.
When the whirring stops under the battery, there is a fan still running that can be heard from the bonnet vent.
Clarification from me, the voltages I quoted are for the lockout of the unit, a battery reset will clear these if necessary. The voltages TJH quotes are in operation that cause a shutdown for the current ignition cycle only, i think.
Excuse the late reply, but I listened to mine and it appears to whine under the wheelarch and also in the bonnet vent. Both stop at the same time, between 2-3 minutes after shutdown.
Since I posted this, the outside temperature has been above 7° where I live so I haven’t been able to test the FBH.
| All times are GMT |
