Home > Maintenance & Mods (L322) > removal of rear wiper arm?
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
just fitted a new wiper blade and seen there is quite a bit of rust on the arm near the fixing point
had a look on microcat and found the components but no guide how to remove said arm?
given that the actual fixing is underneath the rear 'spoiler' i assume some other bits have to be removed?
seen an arm on fleabay but they say its for 2008 on vogue - thought it should fit all up to at least 2009?
any help appreciated
thanks
Post #53483 8th Mar 2011 12:41pm
dan_uk_1984
You want the workshop manual for the "how too's" Rave will cover this, although in theory Rave stops in 2004/5 most of the body stuff is covered.
In the mean time someone did a writeup with photo's on the motor removal, this should also cover arm removal. I can't seem to find it though, hopefully someone will post it up for you.
I think the main problem is that the water feed goes through the central spigot, which causes it to rust like a Censored .
It's on my list of things to do, I temporarily cleaned mine up with some wd40 and a small wire brush.
Post #53485 8th Mar 2011 12:45pm
slim_sane
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
It's a sticky in this section (Maintenance & Modifications) the link is:
http://www.fullfatrr.com/forum/topic884.html
Post #53486 8th Mar 2011 12:50pm
nick h
thanks Dan - was actually appalled at the degree of rust Sad
Post #53487 8th Mar 2011 12:59pm
nick h
thanks very much Smile
Post #53488 8th Mar 2011 12:59pm
nick h
so should the 2008 'arm' fit?
Post #53489 8th Mar 2011 12:59pm
nick h
bump?
Post #53903 10th Mar 2011 12:38pm
should do nick, the rear window is identical throughout 2002 to the latest RR.. ... - .- -.
Post #53905 10th Mar 2011 12:56pm
nick h
thanks Stan Thumbs Up
Post #53906 10th Mar 2011 1:00pm
