Home > Technical (L322) > Heater issue on Auto
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Unless I'm going mad (quite possible!) I believe that when on Auto, the dotted lights to show the fan speed should still illuminate?
Mine seems to have stopped doing it. The fan works fine, I can turn it up and down manually, and if I select for instance Max Defrost, the fan goes on Max and all the fan dots light up. But not on auto. The fan still seems to be working although perhaps not as much as I would expect (on auto), i.e. its blowing but gently, although as above, I can override that on manual.
Any ideas what this could be? I checked the little grille for the temperature sensor and that seems clean.
Thanks. 5.0 S/C Autobiography - now gone to pastures new....
Post #534850 19th Nov 2019 10:12pm
dazza1983
When On auto none of the dotted lights will be lit up.
Only of auto and when you manually adjust will any of the dots light up.
Oh and with regards to your gentle blowing. If the cabin is near to or up to tempreture then all the climate has to do is keep it there and the blowing will be subtle and gentle. It will continuously adjust speed and which vents the air comes from to maintain the set cabin temperature.
Only when the engine is cold or the car has been sat for hours and then started will the blowers be noisy and fast. Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #534851 19th Nov 2019 10:14pm
Cappo
Thanks Daz, that's one less thing to worry about then! Very Happy
This is my second L322 and I was convinced that the dots lit up on Auto - like I said, must be going mad! 5.0 S/C Autobiography - now gone to pastures new....
Post #534855 19th Nov 2019 10:25pm
BackinBlack
United Kingdom 2005 Range Rover Vogue Td6 Java Black
My 2005 L322 lights up on auto, I checked it this morning.
Post #534880 20th Nov 2019 11:44am
DrRob
2011 = no lights when on Auto. I don't move it off that setting ever. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #534888 20th Nov 2019 1:10pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
My 2009 lights up on auto. Mine is a pre-facelift.
Oh, and to test if auto is working, just turn both temp dials either max down or max up. The fan should soon start working hard.
Mine runs at 2-3 dots all the time. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #534889 20th Nov 2019 1:13pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
2011, no dots when on AUTO and both dot & line are lit, maybe there is a semi auto and full auto mode?
My 2007 Freelander also shows no dots when on AUTO
Post #534894 20th Nov 2019 1:51pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
2007, dots on auto.
Post #534906 20th Nov 2019 6:06pm
mjdronfield
If I remember right, on the earlier cats you could have manual fan speed and auto everything else.....or similar. You press Auto again and it goes back to full auto.
I recon lights are on and it’s all auto....but if you move fan or distribution, their respective lights go out...
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #534908 20th Nov 2019 6:41pm
Cappo
Thoroughly confused now! Mine's a facelift so it seems ike maybe the lights shouldn't be on when on Auto. Other thing is, the fan is running but it doesn't blow hard, not even when I put the temp on min or max. 7am this morning, -3 on the dash, and at 24 degrees it just puffs gently. Got warm enough but didn't try hard!
So I wonder if there is something up after all? 5.0 S/C Autobiography - now gone to pastures new....
Post #534922 20th Nov 2019 8:18pm
mjdronfield
Irrespective of any setting, if you turn the fan up manually using the knob, the fan should increase.....end of.....
If it was in Auto mode, manually changing fan speed will override it.....and fan speed will now be manual.
Does your fan go full speed when you press the Max Defrost button?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #534928 20th Nov 2019 8:29pm
DrRob
Max Defrost on cold mornings should blow the fans full pelt Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #534929 20th Nov 2019 8:30pm
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
2006MY should have dots lit on fan control according to fan speed so you've defo a fault.
Can you read fault codes to see what it throws up as there's a number of possible causes ranging from the HVAC ecu, FSR (less likely), Switch controls and temp valves/sensors.
The electric blower motor speed is controlled by the ATC ECU via an outlet voltage amplifier (FSR) installed in the outlet of the right hand fan. The ATC ECU outputs a stepped control voltage between 0 and 8v to the FSR which regulates the battery feed to the blower via the fusebox. As you can operate the fans manually it would (to me) indicate a possible signal loss from the ECU or a fault in the switch panel itself. Hopefully someone more knowledgeable or experienced will pop along with a better answer but fault codes would help
Post #534946 20th Nov 2019 9:25pm
Cappo
It does run fast when I manually dial it up. I *think* it does for max defrost but I'll check tomorrow. 5.0 S/C Autobiography - now gone to pastures new....
Post #534954 20th Nov 2019 9:56pm
mjdronfield
Just reread your query, apologies, above when I was talking about lights I meant the ones in the Auto button. I see what you mean now.
I’m not sure if the dotted fan speed lights come on when it speeds up and down when it’s in Auto. I can’t remember what mine do.
I’m pretty sure when you press Max Defrost they do....
Don’t forget that when you first start up, if you have heater set at warm, it won’t blow lots as the water temp isn’t up enough to blow the warm air you requested, so it won’t blow till the air can meet your temperature requirements....well, not in Auto anyway....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #534960 20th Nov 2019 10:10pm
