Home > General > Build sheets
Andy
Build sheets
Would it be a LR dealer who would provide me a build sheet for my car or can I search online?
TiA 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #535206 23rd Nov 2019 11:51am
Lyonhead
Wales 2019 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
Andy,
I believe you can get your build sheet off Topix. Just input the VIN number.
But i doubt it would take much for any main LR Dealership to look it up for you and email it over. Saves leaving the house Thumbs Up 19MY SVA-Dynamic Spectral Chromoflair Blue but colour not available in profile
2016 RRS SVR Estoril Blue - Gone
2010 RRS 5.0 Supercharged Navara Bronze - Gone
2008 RRS 4.2 Supercharged Black - Gone
2006 RRS 2.7 Diesel Rimini Red- Gone
Post #535211 23rd Nov 2019 12:19pm
nino_nino
I used this:
www.vindecoderz.com/ 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #535212 23rd Nov 2019 12:25pm
Andy
Thanks.
Using the above I can see my car should have a 110/850ah battery fitted. That’s not AGM either. Equally no recall for fitting an AGM either. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #535218 23rd Nov 2019 1:06pm
Baltic Blue
The recall to upgrade to AGM battery was for very early 4.4 tdv8’s.... late 2010 and early2011... ,after that they were supplied ready fitted from the factory. ( That is what I was told by the MD.) Mine is a May 2011 build, and was recalled.
Post #535220 23rd Nov 2019 1:16pm
neilly
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Topix build on mine says it it Silver.
Sure when I look at it , it is blue.
Cheers
Post #535266 23rd Nov 2019 9:41pm
ilard
Sorry for the noddy question, but did you get the VIN absolutely right? And what does the V5 document say.. blue?
The dealer takes the order, passes to the factory electronically which makes it according to that order, customer then receives the product built. There’s no margin for that size of error. In fact, the only error you will see is if the dealer submits a spec that the customer did not want, because the factory will build to the submitted spec and the production process will generate errors if it does not.
Also see http://www.vindecoderz.com/ as nino_nino suggests... a second opinion on what your car is! L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #535282 24th Nov 2019 12:42am
neilly
Well, TOPIX states Indus Silver , same as last time. in vehicle features tab.
But it is actually baltic blue.
Everything else matches on the features list.
I will check that other link.
Cheers
Post #535292 24th Nov 2019 9:48am
neilly
the second link shows the correct colour, strange that topix has it wrong.
Cheers
Post #535294 24th Nov 2019 9:54am
Rog21
England 2012 Range Rover Vogue TDV8 Buckingham Blue
You can also request the build sheet from LR by sending them an email.
Roger
Post #535617 27th Nov 2019 1:11pm
