Home > Technical (L322) > 2003 L322 Humming Noise and Transmission Problems. |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 308 |
Some outside-the-box ideas you may have already eliminated; wheel balance, tracking, loose undertrays and heat shields. The undertrays can make a proper noise at certain speeds if they are loose... good luck. |
23rd Nov 2019 10:02pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
I had what sounded like a wheel bearing starting to go. Local garage put it up on the ramp and tugged all the wheels, nope not that. On test drive they said it was the gearbox.
23rd Nov 2019 11:38pm |
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
I'd suggest prop shaft out of balance for some reason and gearbox solenoids or other shift/pressure control related components. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
24th Nov 2019 10:07am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2224 |
Interestingly I had a similar situation - I have done a lot of miles and drive hard - I changed all wheel bearings - the fronts fell out of the hub carrier they were so worn also replaced all drive shafts all this minimised the vibration but didnt get rid of the noise. I also replaced front and rear diffs - noise still there. In the end it was the heat shield rubbing on the prop but only when under load and it didnt always do it so the sound seemed to move around. The reason for this was the centre bearing on the prop was shot replaced the bearing and had the splines reset all good
24th Nov 2019 10:51am |
