Home > Maintenance & Mods (L322) > Removing the head M62
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi
I am trying to remove the right hand head off the M62 engine
I did read somewhere, to leave the exhaust manifold on the head and just undo the flange bolts
Trying to get to the flange bolts is another thing.
Would it be of any advantage to remove the plastic guards and the heat deflectors under the fenders, would this give me access?
I have looked through Rave but cant see ay thing.
Or should I take the manifold off and undo the flange bolts
Its not on a hoist
thanks RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #535467 26th Nov 2019 7:34am
p38arover
Australia
WS manual says to remove the manifold. (I have the genuine RAVE disc V015-2 -> 03/2003 LRL0548ENG )
It indicates one will need to unbolt the exhaust from the manifold and lower the exhaust on a jack. Then unbolt the manifold. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #535474 26th Nov 2019 8:48am
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
When I did mine I unbolted the manifold and moved it out of the way to lift the head up and off. There is enough room (just) I left the exhaust in situ 👍
Post #535486 26th Nov 2019 10:23am
knares
thanks guys for your reply's
did you need to loosen the flange bolts RR 2005 4.4 petrol
Post #535503 26th Nov 2019 12:50pm
knares
yes, that worked for me
Post #590986 12th Apr 2021 1:48pm
