Home > Technical (L322) > Help please - dropped hose spring retaining clip!!!
TDV8John
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Baltic Blue wrote:
Would taking the air filter box out help you to get easier access?.
It is a fairly easy job and frees up a big space.
(I have only removed the passenger side one, but I think the drivers is similar.
Mike.
Yes thanks Mike - removing the air filter box was the only realistic way I could get to it as I couldnt get my hands in low enough to get to the bottom hose.
Its not so much access that's the problem more knowing which way to shift that bottom plastic hose connector.
Cheers
John
Post #535393 25th Nov 2019 12:42pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
John,
I think your right, the hose I posted doesnt look the same as yours, but the fitting has the same clip to hold it on.
Looking on the pictures of the water bottle I have seen, the stub on the bottle simply has a 'barb' on it that the metal clip gets caught behind. There is no thread or anything. It is probably just stuck in place with the O ring.
Give it a wiggle and a tug Wink
I would hope the dealers can supply this clip. There are lots of them for VW/Audi on the net but I can't see any listed for LR though. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #535402 25th Nov 2019 2:17pm
TDV8John
OK thanks John, I'll just give it a bit more of a tug when I try again.
I did visit LR dealer earlier today and they were no help unable to supply the clip or the hose fitting itself "..but we can do the whole hose if Sir would like that" Rolling with laughter
I have found a few of the clips themselves online and have ordered a couple that measure up to being the right size so will post an update later in the week when they've arrived.
Best
John.
Post #535412 25th Nov 2019 4:24pm
counter intuituvely you push the clip inwards and the fitting should release. There is nothing that can't be fixed with a hammer😜😜
Post #535544 26th Nov 2019 7:24pm
TDV8John
Oh right, that is very helpful advice thank you!
Replacement clips should arrive tomorrow so will I put it back in and give a try Thumbs Up
John.
Post #535546 26th Nov 2019 7:27pm
JCW
I replaced my expansion tank (oil cooler gasket was leaking and had oily film on the inside of the expansion tank) requiring removal of that lower hose fitting, I also lost the same spring clip but luckily found it hiding in the subframe.
The hose fitting was a tight fit but some firm wiggling eventually freed it, it does just pull off in the obvious direction.
Hope that helps.
Post #535549 26th Nov 2019 7:58pm
TDV8John
OK thanks again.
I'm assuming as per the earlier post I'll need to replace the missing spring clip in order to release the fitting so will give it a go once they've arrived tomorrow.
Thanks all.
John.
Post #535551 26th Nov 2019 8:02pm
JCW
Ps if the clip is completely removed opposed moved into the ‘remove’ position, the fitting should just pull off.
Post #535552 26th Nov 2019 8:03pm
TDV8John
All sorted this morning with the advice above put into action.
Only lost a few drops of coolant when I freed the pipe from the expansion tank and new one now up and running etc.
Many thanks everyone!
John.
Post #536068 1st Dec 2019 1:37pm
Brill Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #536071 1st Dec 2019 1:53pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Hi TDV8John,
Can you advise if the spring clip you ordered was the right one? And if so where from?
Mine sprung off never to be seen again... 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #542653 1st Feb 2020 3:49pm
TDV8_Tommy
Found the spring clip... Very Happy Very Happy Very Happy
After a 3 hour search... Censored
Front bumper off and drivers headlight removed to gain access and light Shocked 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #542792 2nd Feb 2020 6:38pm
