![]() | Home > Maintenance & Mods (L322) > Mega flush Milton Keynes |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102 ![]() ![]() ![]() |
Bodsy is your man!
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
I tried Bodsy, got some initial responses and then he went radio silent on me :/ Tried a few times and just didnt reply. Worked out in the end as someone recommended JGS in Isham, seem to get great reviews and worked out £70 cheaper too.
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 193 ![]() ![]() |
Thanks for the replies |
I phoned Bodsy but like M@]{ after my 1st call, when I tried to contact him to book a date, he seemed to keep switching his phone to answer mode, after the third time of asking him to contact me I think I will have to try elsewhere. JGS 4x4 do offer a mega flush service, they replace the drained oil with a spec called ROCK OIL ATF D VI. Can anyone confirm this is the best oil to replace what is in the 8 speed gearbox. |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
I would assume ZF Lifeguard 8 which is from the manufacturer of the gearbox is what could be considered the best formulated oil for your particular gearbox. It's fairly expensive stuff compared to other ATF fluids.
Here is the spec sheet for that Rock oil. Did they give you the option of using a different oil? You've got me thinking now......
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3881 ![]() ![]() ![]() |
One tip....
JGS 4x4 say they can do it, would cost another £180. However they say it is not necessary as the gauze is cleaned as part of the flush? |
Had a call from Bodsy today, he apologised for not responding earlier and we have arranged for him to visit me this coming Tuesday. I feel comparing the two options, Bodsy, being recommended by so many on the forum, gives me that little bit more confidence when allowing someone to mess around with my pride and joy. |
Did he mention what oil he uses? And whether to change the pan/gauze/filter? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Great news! Bodsy flushed mine as part of my preventative maintenance plan. No symptoms before or after. That is key.
He told me it's not necessary to change the filter. I assume he is going to use an oil recommend for the 8 speed gearbox. |
Be interesting to know what oil he puts in and whether it's ZF Lifeguard? Although when you price that up is over £400 so unless they get some sort of monster discount they're not putting that in for a job price of £280 / £350
Bodsy uses an exact specification oil for the 8 speed. There are rules governing oil spec so just trust him |
