![]() | Home > Technical (L322) > L322 Articulation Validity Fault |
PovertySpec Member Since: 28 Nov 2019 Location: Durham Posts: 35 ![]() ![]() ![]() |
Hi all, I appreciate there are multiple threads on this subject however I've a couple of questions that I'm trying to get definitive answers on.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
1) Yes
Thanks for the reply, to answer you:
Progress....of sorts.
I assume you mean knackered and not missing completely ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
There's a whole other story there.....which I will cover at some point. Anyway, current readings are: Front Right: Voltage : 3.90 Height : -47.83mm Front Left: Voltage : 45.01 Height : -7.93mm Rear Right: Voltage : 1.84 Height : 21.88mm Rear Left: Voltage : 2.45 Height : -9.75 The Rear Right was the one replaced. I assume because it shows positive, and the other 3 negative, that would be the cause of the articulation error, so I need to get it calibrated. Although the Front Right seems excessive too. What are the options with regards to doing it myself - it's an 03 plate if that affects the kit used. |
Not sure how to rotate...bear with...but it seems ok?
and the Front Left ? .
Do the tyres on RL and FR look more compressed (flatter...) than the other two. We have seen this before where the car is more or less teetering on two wheels due to height settings being out of kilter .
Front left.....still don’t know why it’s rotating
flashgordon Member Since: 23 Sep 2019 Location: Hannover Posts: 76 ![]() ![]() |
--->> Is it the rear right sensor (new one) that is still giving you a Problem? what I found out: when I got sensor-warning-messages my IID tool shows it is always the rear right one.... so ... is there something special with the right rear one? . |
Ok.....bit of an update, upgraded to a Foxwell NT 520 tool as that has the ability to calibrate the air suspension.
This may be a Christmas miracle.....
