Home > Maintenance & Mods (L322) > Rear Washer. Not the usual problem...
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Had my rear washer jet apart today. I'd assumed it wasn't working because the jet was blocked, like the last 4 i've owned!
It turned out to be clear and the problem seems to be somewhere else. I pressed it to wash about 20 times with the tube off (at the back). You can hear the motor fire up at the front and a bit of water even came out after one of the presses. But nothing since.
Anyone experienced this/ anything other than a blocked jet?
My next step would probably be to try and dismantle the bottle and see if theres a block at that end. Looks like a pain in the ass though as I'd need to take the wheel and inner wing off to get to it.....
Question My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #53561 8th Mar 2011 8:11pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
I believe there's an in line non return valve, although I'm not sure where it's located.
Gone - Range Rover Supercharged 2006
Post #53562 8th Mar 2011 8:19pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Mine ain't right. I'll be pressing it for ages and nothing will happen then all of sudden screen wash will appear. Kinda like a delayed reaction. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #53567 8th Mar 2011 8:46pm
Hi Guys
I went through this a few weeks back. Search my old posts about a weekends work and there are amfewnpics showing the NRV. Mine was blocked and think it's not working as it takes about 3-4 cycles to get water to it so must be draining back to the bottle.
Post #53571 8th Mar 2011 9:06pm
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
My local service agent Guava fixed mine in ten minutes while I had a cup of coffee, free of charge. Blocked non return valve apparently, frequent issue so they say. 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #53576 8th Mar 2011 9:33pm
http://www.fullfatrr.com/forum/topic4806.html?highlight=busy
Post #53580 8th Mar 2011 10:03pm
hoppy_70
Hmmmmmmmm, i've definately got some ideas from that. My non return valve IS blocked but I took it off and tried it without. I wonder if it can drain back so quickly that nothing would come out without a valve attached?
I'll get a new one/ try cleaning the old one and take it from there.
watch this space Thumbs Up My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #53612 9th Mar 2011 9:31am
I would just replace the NRV. i took mine apart and not worth the hassle for a £3 part. when mine was off made sure i had loads of water coming through. What was there was pretty crappy until flushed!
Post #53720 9th Mar 2011 4:49pm
hoppy_70
Think it must be something other than the NRV. Can't get it to fire water out even with it off.
Does anyone think some near boiling water in the screenwash tub would be a dumb idea?
When I dropped the NRV in boiling water it seemed to dislodge some crap, I was wondering if putting it in the screenwash bottle would have the same effect? My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #53732 9th Mar 2011 6:20pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Could always try some CILLIT BANG in there.. Shocked Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #53746 9th Mar 2011 6:37pm
We laugh but they use it to clean up when decommission nuclear power plants Thumbs Up 2008 MY Supercharged
Post #53788 9th Mar 2011 8:25pm
paneldamage
I had to do my pump due to this problem. When you get the wheel off, you dont need to remove the entire wheel arch liner, just undo enough to peel the corner back and its flexible enough to fold out of the way. Theres three pumps come in to view - make sure you get the right one.
Have fun now....
Post #53831 9th Mar 2011 11:10pm
