![]() | Home > Maintenance & Mods (L405) > Vehicle vibrates on brake |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 ![]() ![]() ![]() |
Could be an issue with the front disks / pads ? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
If the vibration is felt through the steering wheel it’s usually the fronts. If it’s felt through your seat, the rears.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
Most likely brake discs but I have known a buckled alloy wheel give similar symptoms 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
I had the same issue on my L322, it wasn't bad, but it was noticeable.
Talking of wheels, I managed to scrape NSR turning a bit too sharp out of a left turn junction today. Running Continentals on the dreaded 22 inch wheels and I think it boils down to the tyres being more or less level with the rims. I have another car running low profiles (Michelin Pilot) and they have rubber sticking out beyond the rim as protection to the occasional light contact. |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 ![]() |
Thanks guys. I will I guess bite the bullet and replace the front ones as well. Plenty of life on the pads as well as the disc visually. What a waste. I hope it fixes.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Before you replace the front discs/pads have the front lower arms checked! We get this often with 405's! If the bushes are collapsing then it makes a vibration that most of my customers report as brake imbalance... |
Hi Craig
The lower front arms have a large bush one end... See how much movement there is? Has the rubber started to break up and crack? It’s usually very obvious! Check with a bar as to how far they move?
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
in addition to what Craig says, binding front calipers can produce vibration too, but you'd notice heat on the wheel/smoke in bad cases. Only Range Rovers since 1988 |
Didn't update this. It was the front disc on the inner side, both of them pitted. Replaced that with pads and issue went away. Brakes work very good now. |
