![]() | Home > Maintenance & Mods (L322) > Lots of condensation on inside of windscreen every morning |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
Sounds like you have a leak - at least water somewhere
Definitely have water in it Dan, classic symptoms... |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
Just sold my mother's car, which had exactly the same. Her car definitely had a leak though.
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
My 4.2 SC does that too. One time I noticed it in the evening so I got in to mop up and noticed how very warm it was inside the car. I left both front doors open for 10 mins till the inside and outside air temperatures equalised and the condensation disappeared and the windscreen was still clear the next morning.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2282 ![]() ![]() ![]() |
What’s the best way to do some leak investigation?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
You got a sun roof? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
Do you run with the air con on
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701 ![]() ![]() ![]() |
A smoke bomb (serious) will find any gaps & show with errrr smoke!
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
Keep the pressure washer away from the sunroof. If it didn't leak before the test, it will afterwards!
Hi All
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3957 ![]() ![]() ![]() |
Don't jump to the conclusion that there must be a leak. All three of my cars (SWMBO's one is actually new) have all suffered from significant condensation (water running down the inside of the windscreen) during the recent cold snap. However, they all recovered just fine after the initial condensation was removed (good old fashioned chamois) and as it has got warmer the problem has not reoccured. I'm not suggesting that it is not a leak, it may well be, but dry it out and see if it happens again.
That’s a fair point.
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 556 ![]() ![]() |
I had similar when I had the windscreen replaced a few years back on my old 4.2. It hadn't been fully sealed and allowed moisture to get in.
I had a new windscreen but also had sunroof leak so hopefully a smoke test will rule in or out some of this... Current stable:
