Home > Technical (L322) > Possible progress with FBH after AGM battery install. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
So I bit the bullet yesterday and fitted the 019 AGM that had been sitting in my garage for two weeks.
2nd Dec 2019 11:54am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Likely to be low fuel, yes Current: 2011 FFRR Vogue SE 4.4 TDV8
2nd Dec 2019 12:19pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4228 |
Fill up and try again tomorrow 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2nd Dec 2019 1:06pm |
I’ve never heard this ticking before so we are getting somewhere. If did tick slow to start off with, then started speeding up- is that normal? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
2nd Dec 2019 1:15pm |
What’s the fuel level before it stops working? I think I read somewhere that it’s 1/4 of a tank? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
2nd Dec 2019 7:05pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
I would also be interested to know if the ATC module assesses fuel for the FBH, the workshop manuals don’t mention fuel levels only temperatures and voltage - but like Andy I feel I have read this somewhere. Ours will fire with the fuel light on I know that much. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
2nd Dec 2019 7:48pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
My FBH ran fine yesterday with an indicated range of 60 miles left, if that helps. Too many toys, not enough time
3rd Dec 2019 1:55pm |
Ah. Mine was 110 miles. I’m filling it up today so I’ll try it again tonight 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
3rd Dec 2019 2:11pm |
Back to normal this morning. Half a tank of diesel and 3° outside and no FBH working. No ticking this time either. 😡 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
5th Dec 2019 10:28am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
Sounds like it's locked itself out. You may need to pull the fuse to reset it. It's in the underbonnet fusebox on mine.
5th Dec 2019 1:16pm |
It’s a PITA to keep taking the fuse box cover off to access the fuse! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
5th Dec 2019 1:33pm |
If you start the engine from cold, can you detect any exhaust from the FBH ?
5th Dec 2019 2:09pm |
I’ll check that later when I get back. I have heard the ticking sound on occasion when I first start the car so it may be working on start up. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
5th Dec 2019 3:36pm |
Pulled the fuse under the bonnet- still blowing cold. I give up! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
8th Dec 2019 11:18pm |
