Home > Maintenance & Mods (L322) > 2004 4.4 v8 petrol gearbox woes
Myblackt5
Hello all, my 2004 L322 has just turned over to 86 k miles and the transmission has started to judder . I've hardly used the car since. I was trying to get some Lubegard shudder fix into it. I have read that a full transmission and oil and filter change is the best thing to do, so I've had a search of the forums, before I put up this post. Has anyone put a how to guide with pictures on here. I spoke with my local garage but they wont touch it because "Range Rover gearboxes are troublesome" .
Can anyone point me in the right direction, or know of a garage in Cornwall that is competent enough to do it?
Post #536201 2nd Dec 2019 10:43pm
Gsxr1250dave
Tyr this first
Change the oil cooler, filter and oil in the 1st instance
Post #536207 2nd Dec 2019 11:13pm
Danwilderspin
does it shudder in manual mode? mine always was a bit lurch between gears as it aged (185k) but silky smooth in manual never fixed it just used it at that age Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #536468 5th Dec 2019 3:44pm
Myblackt5
I've not tried it in Manual mode since I noticed the shudder. I might give it a go.
I'm going to drop the fluid and change the filter at the weekend.
Post #536470 5th Dec 2019 3:46pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Suggest a PM to RRPhil
Post #536478 5th Dec 2019 5:27pm
RRPhil
If the torque converter lock-up clutch is the culprit, then it will sound a bit like driving over a cattle grid during the vibration. If you look closely, you should also see the rev. counter needle wavering a couple of hundred rpm in sympathy with the noise.
Although a friction modifier like Instant Shudder Fixx may temporarily mask the issue, it doesn’t put friction material back onto the LUC friction plate. It also effects the friction characteristics of the other 6 clutches in the transmission. If the resulting modified friction coefficient is still within the adaption range of the solenoids, you’ll get away with it. If it isn’t, you’ll get uncontrolled clutch slip and could trash your transmission.
Phil
Post #536486 5th Dec 2019 6:57pm
