![]() | Home > Technical (L322) > Front End on bumpstops most mornings |
Does/will your car achieve full off road height? |
Outlawd3 Member Since: 19 Oct 2019 Location: Mt Ayr, IA Posts: 8 ![]() ![]() ![]() |
Yes it does. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2748 ![]() ![]() |
Go to off-road height then spray soapy water around the base of both air-springs which will probably reveal a multitude of pin-holes, possibly on both. Consider replacing the whole strut rather than just the air-spring, maybe both even of only 1 is leaking as the other wont be far behind. |
I have tried that, but certainly will try it again. It seems like it takes it over 8 hours to start leaking down. I will plan on replacing both air struts. I do park on a slight incline at home. Would the self leveling be causing any of this or height sensors ? The height has been calibrated and seems to go right back to that. I just wanted to see if anyone else had ran across this to see if there was something else I might be overlooking. |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
when the engines off, doesn't the ecu check height sensors every 2 hours or so and deflates air bags to compensate?
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
Try parking the other way round , if still dropped than it isn’t the ecu compensating fir the slope 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Mine does the same if left for 2 or 3 days. My TD6 did too. In fact I seem to remember the back went down too after a week or so.
dexion7 - I had wondered the same thing. I might start with new height sensors.
If the 20A main suspension fuse is removed overnight then the system cannot lower unless air is escaping from somewhere. I expect that in the morning one front corner would be lower than the other indicating a leak in the lower side.
I removed the 20 amp fuse and parked on level ground last night. The front end was on the bumpstops again this morning. So I am convinced it is a leak. I would think if one of the front air bags is leaking it would only go down on that side. Is that not correct ? Or does the system leak out both through one or the other front air bags, if one had a leak ? |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
behind front right wheel liner is cross over valve for front suspension. check that for leaks. 2012 TDV8 Black Edition
I had checked the cross link valve and seen no visible leaks, but went ahead and replaced it last week in case of internal leak, but still goes down in the front overnight. |
Both air-springs are likely to be leaking. The holes generally start as pin-holes then get bigger and more occur. However make sure that both top nuts are properly tight, for which you will need an Allen key or Allen key socket to hold the shaft and a ring spanner for the nut. |
GraemeS - on the top nuts, are you talking about the 3 at the top of the strut that are visible under the hood ? |
