Home > Technical (L322) > And THIS is WHAT leaking ???
Markwood71
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
So - smell of diesel/ oil in cab last few weeks. Nothing major , but enough to notice.
Filled up washer bottler tonight and noticed this - no drips on the drive , so not a massive leak- but any ideas what or why ?
3.6 V8 2010.
 Welcome Rosie J - The Newer Kid on the Block
RIP Rosie (We all Love Rosie - especially in S mode at the traffic lights)
Post #536382 4th Dec 2019 8:25pm
Fox889
I maybe well off track, but that looks like the exhaust from the fuel burner heater? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #536386 4th Dec 2019 9:15pm
Markwood71
Could be - I’m a bit concerned about the oil on it ,possible split in the hose meaning we are getting the oil smell in the cab I guess.
If it ever stops raining I’ll get underneath tomorrow... Welcome Rosie J - The Newer Kid on the Block
Post #536611 6th Dec 2019 11:34pm
Fox889
Could be burnt diesel gases & not oil?
Just guessing Razz 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #536612 6th Dec 2019 11:40pm
TJH1985
That looks like just below the shields, if it’s diesel then a common issue is the leak off pipe o rings on the injectors. I was convinced ours was oil until I cleaned it all up and realised it came back clear.
They will only leak when the engine is running, so if you pull on the drive and switch off straight away you’ll not notice the leak, simple check is to raise it into off road height and start the engine then check for drips after 5 minutes or so again if it’s diesel it’s fairly clean.
Here’s what our old ones looked like vs new, you can see a small split:
New ones fitted:
Here is a video of ours leaking, easy to check if you do decide it’s coming from behind the shields and take the shields off to check.
FBH Exhaust comes down behind your wheel arch covers and exists much lower than your picture.
If it’s oil, I have had to do the rocker cover gaskets ours leaked around the injectors, oil filled the injector holes until it saturated the sound deadening on the black shields and finally began to leak.
You can see the new seal here:
It was clearly coming up past the injectors:
 Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #536623 7th Dec 2019 8:56am
Markwood71
That’s really interesting- I’ll have a look next time I’m out. Thanks very much for that info 👍👍 Welcome Rosie J - The Newer Kid on the Block
Post #536700 8th Dec 2019 10:48am
