Home > Technical (L322) > Shudder at 40kph +/- 5 or 6 kph |
RaveRover Member Since: 14 Mar 2017 Location: Melbourne Posts: 36 |
Hi. Haven't posted in a while. Lately I've been getting a shudder in the drive train at or about 40kph. Much worse under load..I.e towing a caravan is diabolical with this issue. I can alleviate the shuddering if I back off the power as I accelerate through this speed range. I originally thought it was the front prop shaft developing an out of balance issue at a certain rpm. I had been under the car and found the shaft to have a lot slackness and lateral play. Changed it out with a good s/h unit but the shuddering is still present, but less intense, so I can accelerate harder with less shudder. My thought now is I've probably fixed a side issue rather than the root cause. I've read it could be a LUC wear plate in the torque converter.. Could a broken engine mount give the same or similar effect ? Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
15th Nov 2019 12:47am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
If you think its the lock-up clutch ( feels like driving over cattle grid ) The cheapest test would be to add https://www.youtube.com/watch?v=l3RmaLuhMjA to see if it changes anything.
15th Nov 2019 6:17am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3192 |
Probably not the case with your situation but a sticking caliper can cause a shudder like going over a cattle grid. Easy to check and eliminate. After a short run check the wheels to see if one is hotter than the others. John
15th Nov 2019 9:16am |
Thanx for the tips guys.
15th Nov 2019 10:12pm |
I hope you changed the filter. I have used Nulon Multi Vehicle Full Synthetic fluid and BMW x5 3.d filter in my td6. Never had any issue. There was a thread about 2 months back showing how to flush the torque converter and oil cooler, very simple process. 2007 TDV8 VSE
16th Nov 2019 1:50am |
Oh yeah, dropped the pan, changed the filter, cleaned everything up incl the 4 lil magnets. Refitted with ultra blue gasket maker and refilled using the correct procedure. A full flush from the cooler wouldn't be a bad idea. Would it pump all the fluid out (8.8 litres or so) if I disconnected the pipe? Or would it just empty the sump and stop, maybe 4 litres.
16th Nov 2019 2:03am |
Sorry, 6litres for the refill. When I said partial, I meant that I only replaced 4 litres out of the 6 (put 2 litres of the used oil back in). At the time I wasn't sure how much I'd need so I only bought 4 ltrs of the full synth fluid. I figured it can't be all bad as the fluid is meant to be sealed for life. The viscosity of the old fluid seemed similar to the new. Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
16th Nov 2019 2:11am |
I tube,https://www.ebay.com.au/itm/Original-Insta...SwFbpaonjl 2007 TDV8 VSE
16th Nov 2019 10:19am |
Ok. I have put 2 tubes in over the space of 2 weeks, I have noticed an improvement, normal driving is a lot better but still have to be real careful when towing.. the shuddering has changed its character a little as well. previously it was more of a cattle grate noise at 30 - 40kph, now the vibrations have become further apart.. more like driving over those warning ripples before you come to a T intersection at speed on a country road.. hard to explain. Thinking it could even be a gearbox mount.
9th Dec 2019 8:04am |
Update and resolution to this issue:
2nd Feb 2020 6:33am |
