Home > Technical (L322) > Parking sensor fault
Fur3rd
Hi all. I am new lol. Bought my first ffrr yesterday very much an upgrade from a discovery 2 Laughing it’s a 2011 vogue se 4.4tdv8
I have a few Niggles with it but I used this to bring the price down.
The first one I am looking at fixing myself if I can is the parking sensors. They don’t work not at all. There no light on the switch and no sound to indicate there not working. I ve checked the fuse and it’s all ok and the reverse camera works when needed as to the other four cameras. Any pointers. Fuse I checked was In then boot. Would removing the switch be next ?
Matt
Post #536934 10th Dec 2019 8:36pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Check the parking module in the rear near side cubby, mine had condensation in it & it packed up.
Easy enough to remove & check inside for any water dammage.
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #536959 10th Dec 2019 10:58pm
Fur3rd
Thanks I will check is this behind rear fuse board?
Post #536976 11th Dec 2019 8:09am
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
No should be other side under the nav dvd (at least mine was on 2012 model when I had a similar issue).
 Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #536988 11th Dec 2019 9:37am
RJH
No, it's the opposite side. Left side as you stand at the rear.
There are some pictures in my gallery of it.
It's the one with 2x brown plugs coming out of the top 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #536989 11th Dec 2019 9:39am
Fur3rd
thanks for all the help took the unit out and it was full of water Sad
shall purchase a new one hopefully it fixes the issue Bow down
Post #537010 11th Dec 2019 12:46pm
