Home > Maintenance & Mods (L322) > Greasy Windscreen - Cleaning tips
Baltic Blue
Somehow my windscreen has suddenly become very greasy when it rains and no amount of washing it with very hot soapy water or using glass cleaner improves it.
It appears spotlessly clean in the dry and crystal clear, but as soon as it rains it smears badly and no amount of screenwash clears it.
It is particularly bad driving towards the sun at this time of year when it is so low in the sky.
My wife suggests I should clean it inside and out with vinegar but I can’t stand the smell.
Any tips what else to try ??
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #537004 11th Dec 2019 12:18pm
ur20v
A Trap
Get some cutting compound and a polishing machine and give it a good polish before a clean/polish with alcohol
Post #537006 11th Dec 2019 12:25pm
rjff
Get the wife to use the vinegar for you!! Smile
Or you could try Barkeeprers' Friend, in powder form. ISTR I got mine from the Range, but it's available on line.
Another tip, find a good commercial cleaning supply company with a showroon and talk to them. I use a glass cleaner suppplied by one, but have the advantage of that company having a detailing nut as a showroom boss. The one I have glass is Brite by Clover of Whalley Bridge. Clean microfibre cloth and done regularly between snow foam and car clean.
Road film remover would likely work, but you need to be sure all residue is removed so perhaps finish with Isopropanol alcohol. The 99% stuff not general rubbing alcohol. Perhaps try it on a small area then finish with the Brite type of stuff.
And make sure the wiper blades are clean. In fact change them at the same time as a good screen clean. Amazing how much crud comes back off them. Cheers
Richard
Gap IIDBT
Post #537007 11th Dec 2019 12:37pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Re: Greasy Windscreen - Cleaning tips
Mike
Not a very nice comment about your wife...........
Post #537009 11th Dec 2019 12:42pm
rjff
Mike
Just had a chat with the guy I mentioned and his suggestion is to use a good qality multi surface cleaner, undiluted. Leave it on for a while to soak and then scrub with a non stick scouring pad, white, but similar to a green kitchen pad. Wash of with lots of water and repeat as required. Remove all the residue, which will remain, with a glass cleaner or IPA 99%.
You may need a sap remover too, if you're near trees.
Basically same as I do. The chemicals I use are Ubik 2000, a univeral cleaner and Brite class cleaner. These are from Clover Chemicals, 20 miles from Oldham. They have various distibutors so perhaps give them a call.
http://www.cloverchem.co.uk/2013/uk/contact_us.asp
Hope it helps Cheers
Richard
Gap IIDBT
Post #537013 11th Dec 2019 1:05pm
CS
Have you tried Autoglym glass polish (inside and outside of windscreen)? I find it very effective. The accumulation of dirt on the inside can be surprising. Maybe check/replace wiper blades too. Only Range Rovers since 1988
Post #537017 11th Dec 2019 1:49pm
i'd try new wipers as suggested by CS.. ... - .- -.
Post #537018 11th Dec 2019 1:52pm
GGDR
all the above are good tips - plus there are glass-specific microfibre cloths Mike
Use two, one to apply, the other to buff
. Cheers, Greg
Post #537020 11th Dec 2019 2:09pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
new wipers, and i use a product called 20/20 by autosmart works wonders on windscreens insdie and out.
also very good for the oven door.
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #537024 11th Dec 2019 2:18pm
Baltic Blue
Thanks, gents, plenty for me to try.
I will start again by changing the blades then the multi surface cleaner with plenty of elbow grease.
I am off into North Wales tomorrow, so it will be stood outside for a few days and in need of a good clean by Sunday when I return.
Cheers
Post #537029 11th Dec 2019 2:38pm
Thanks for that Matt, just ordered some Thumbs Up
Post #537030 11th Dec 2019 2:40pm
MattHughes86
Your Welcome Craig.
i have used it for years and on nasty nasty wind screens, lifts smokers grime, mud, and everything else that the mind wont work on right now.
its also good for clean up shiny surfaces and then you can polish properly after
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #537033 11th Dec 2019 2:44pm
Wifey has a new oven so it might persuade the glass to keep clean Whistle Very Happy
Post #537034 11th Dec 2019 2:52pm
rjff
Mike
Clean the screen THEN change the wiper blades or you'll oily have to do it again. Cheers
Richard
Gap IIDBT
Post #537044 11th Dec 2019 3:18pm
Baltic Blue
Thumbs Up Thumbs Up G reg 2.5VM Vogue Portofino red 1991- 1999
Post #537045 11th Dec 2019 3:24pm
