![]() | Home > Technical (L322) > Which suspension have I got? |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
You have Continuous Variable Damping, for the rear shock - they are known to "sweat" a bit but are OK. so if oil is not dripping You are ok 2012 TDV8 Black Edition
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2734 ![]() ![]() |
I fitted Bilsteins - cheaper than LR but no adverse effects. |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 429 ![]() ![]() ![]() |
Thanks, chaps.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
The hard ride may be more down to the (lack of) sidewall in the tyre?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3853 ![]() ![]() ![]() |
Or next time you fit new tyres consider 255 55 20.
Can you go to “19s on Brembo braked FFRRs? 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
Got these on mine 19" running255/55/19
D4 19" fit - I've had a set on mine and most likely will go back to 19" when the current 275/55R20 need replacing as I find them too big and nothing much here in 255/55R20. |
Yes, but only on that one style of wheel I believe. Other 19's will foul the calipers. Mike |
