![]() | Home > Technical (L322) > Wynns EGR cleaner. Slight juddering when first starting. |
If you shoot egr cleaner into the air inlet any crud you loosen will end up passing through the engine and out the exhaust.
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
Fair point nicedayforit. Thanks. I have considered that, but having looked at the guide on here I am quite daunted by the process to get to the EGR - I looked at this:
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 775 ![]() ![]() |
I'm not one for scaremongering but if you have any doubts about EGR operation I would suggest that you replace them rather than clean them. If one fails it can wreck the turbo then it's the end of the car.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
As above, best to check them out throughly. I check the actual vs commanded whenever I have serviced it given its a known issue.
My experience is only with my TD6 which is relatively simple if filthy and doesn't affect any coding.
I've just re read your symptoms, have you checked the codes again to see if the previous codes were red herrings?
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
From your description, 'slight juddering' when cold maneuvering, goes away when warmed up a bit.
Morning all,
"Codes P045C EGR control circuit "B" means no low voltage change to indicate the EGR is opening or closing. P045D is basically identical but it means circuit high as opposed to low/"
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
At some stage, I'm going to strip down the intake side of things and clean it back to new. Or just buy new bits and save all the work cleaning |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
A word from the wise. Treat them as service items and replace them.
J-rov, I am only a short way into your link/post. Wow. I wish I had the courage,space and tools to do that.
Hi, yeah was a bit of a mission but worth doing as the cost of giving it to a garage was far more (plus I never had confidence they could do it properly!). Just had to be methodical and think ahead!
Yes, I was always surprised to see it there, every time I went to the indy. Taking up workshop space, with a workshop blanket over the front and various bits of the car and engine stored in the cabin and boot. A heart breaking sight to see, and I would have been v unhappy as well.
