![]() | Home > Maintenance & Mods (L322) > Wheel Alignment Recommendations |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
Pro tyres did a pretty decent job on both of mine |
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
I've been thinking about getting this done too. Is there anything we need to be aware of when getting the alignment done on these? Any quirky suspension components that would make a regular alignment tricky? |
Talkwrench Member Since: 26 Nov 2019 Location: Lytham St Annes Posts: 17 ![]() ![]() ![]() |
Thanks for the replies,
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Make sure all suspension bushes etc are in good order first. They may find this out during the alignment. Pause, get bushes done and then repeat alignment.
Dr Rob, thanks for that. I'm aware of the importance of the bushes being in good order. But the tight tolerance mode is new to me, does this pertain to the measurement equipment?
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 782 ![]() ![]() |
I’ve used Kwik fit - I don’t know if they still do it but they had an offer of £100 for unlimited checks and adjustments for 2 years, I certainly got my money’s worth.
So it sounds like I'll need to take it to the stealership or LR specialist if I don't have access to IID tool or similar in order to get the most out of the job and at least have a fighting chance of it being right. I've just spoken to the dealers and they're quoting £150 all in for the 4 wheel alignment and I can only assume they will follow the procedure outlined by JLR? Cheers, Andy
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
I had mine done (years ago) at ATS in Leyland. I watched the geometry being adjusted ‘live’ on the screen in the waiting room as they turned the various eccentric adjustment bolts to make the necessary corrections. The previous week I’d had the geometry ‘checked’ at a nearby tyre-fitting place who claimed they’d adjusted everything properly, yet my L322 still pulled to one side. I remember telling the ATS guy this and he said “well they did a good job of putting the rust back on the adjusting bolts after they’d done it, then”. Like I said, this was years ago so I don’t know if they still have the same kit.
“well they did a good job of putting the rust back on the adjusting bolts after they’d done it, then” |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
Try this link from the Wiki for the WM.
A decent place will have their own IID or similar electronic plug-in hand held to put it into Tight Tolerance Mode. Only a plug in can do this, it’s not something that can be done via the onboard menus.
Use the weblink I posted and find a few and call them.
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
Come over here, I'll stick it on my son in law's Hunter + computer ramps.
TomV8 Member Since: 25 Sep 2017 Location: Yorkshire Posts: 107 ![]() ![]() ![]() |
Not exactly local to Lancashire but Chris at Center Gravity in Atherstone in Warwickshire takes chassis set up to the highest level. Www.centergravity.co.uk |
