Home > Maintenance & Mods (L322) > Lower Front Trim Panels
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Just had all the welding done on my vehicle (see my previous posts 'what lies beneath' for details) , gave permission for the welder to chop the side steps off as they were rotten , had a new replacement set fitted by the garage but fitted the front mudflaps myself before the steps were fitted. What I need to do is re-bolt the front mudflaps to the side trims below the side intake trims , so does anyone know how I can remove them or gain access to fit the mudflap side bolts please ?
Post #537962 20th Dec 2019 9:48am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
You need to remove the lower panel - pulls off once you remove (or perhaps just loosen) one or two bolts (usually rusted solid) at the joint with the wing Thumbs Up
Post #537963 20th Dec 2019 10:01am
mercs600
Thanks for that , Im sure there are 2 x screws at the top (that look very corroded !) , that needs to be undone. Trust it to be raining now Sad Will put it up on the wheel ramps and see if I can get access Smile
Post #537969 20th Dec 2019 10:53am
JCW
If you can get a spanner on both ends, they usually end up snapping, 10mm from memory.
Post #537970 20th Dec 2019 11:06am
mercs600
Thanks , I will replace with stainless when I eventually get them off Smile
Post #537984 20th Dec 2019 12:21pm
