![]() | Home > Technical (L322) > Restricted Performance? Could this be the culprit? - FIXED! |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3267 ![]() ![]() ![]() |
@GGDR
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
So, got a call from the garage, they replaced the manifold sensor that relates to the P040D-00 (2F) fault code I was getting - reset the faults and the Restricted Performance message has gone and not come back. they test drove for 15mins, all ok. I picked it up and did a 20mile round trip, it did it's regen thing, soot levels went from 20.7 to 4.2 and still no sign of the Restricted Performance warning!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Good news |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
Glad it's sorted Mark.
It is at first a reasonable deduction that dead sensor saying 100 degrees is the same sensor as the one in the manifold throwing the code P040D-00 (2F). And therefore a conclusion they are one in the same, However we worked out that the sensor that mostly sits at 100 degrees is post turbo #2. Boot it enough to spool up the secondary and you'll see it rise. Have a light read here, quite a journey: https://www.fullfatrr.com/forum/topic48131.html This was a feeder to the P040D-00 (2F) fix you probably already read: https://www.fullfatrr.com/forum/topic50202.html There are 5 EGT sensors but only 4 values that will show on the IID. We established that the sensor in the manifold's value isn't read by the GapIID, (other than when it throws an error). You can see here there are more sensors than the IID shows:
Yours? Dunno. Pro-level tools can do more than the IID and perhaps there was an error that the garage's tool cleared, one that the IID didn't see. What I don't get is where did you see a 900 degree reading? On what sensor was that? But chuffed you have your car sorted before Christmas. Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway Last edited by GGDR on 24th Dec 2019 12:42pm. Edited 1 time in total |
So a summary of the symptoms and resolution, so it may help others:
Yours is odd for sure Mark.
Here's the log / graph showing the spike. This was at idle (the spikes went a lot higher when driving)
you've got a 400 spike there...?
