Home > Technical (L322) > Brake squeak when reversing
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
My 2011 TDV8 has developed a squeak from rear brakes when reversing. I suspected sticking rear callipers but have had them off for freeing off and greasing however the squeak is still there, so now I am thinking park brake. Has none else had this? 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #538407 24th Dec 2019 2:09pm
could be a bit of grit/stone between the backplate and disc... ... - .- -.
Post #538409 24th Dec 2019 2:14pm
Baltic Blue
One of the retaining springs broke on my td6 Park brake and I only heard that when reversing, but I am not sure if it is different on the 2011., but definitely worth getting someone to listen while you reverse, at least to determine which side is squeaking.
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #538412 24th Dec 2019 2:31pm
scuddriver
But I guess I would hear a squeak going forward as well as back? 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #538414 24th Dec 2019 3:36pm
cass
Not necessarily- my 2011 only made a noise in reverse when the pin snapped
Post #538416 24th Dec 2019 3:44pm
Strip and clean the calipers
Failing that have the discs off and strip And clean the hand brake mechanism.
Together these should sort any problems. There is nothing that can't be fixed with a hammer😜😜
Post #538570 26th Dec 2019 11:27pm
