Home > Technical (L322) > FBH
dan_uk_1984
Worth noting is that the FBH will cut out if your battery drops below 11.5V so if your battery isnt healthy it will shut down after a few minutes - this is happening on mine atm. I verified this by plugging the charger in and it then ran full cycle.
D
Post #52434 2nd Mar 2011 10:10am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Cool
So what does "Full Cycle" actually mean. I didn't see anything in the manwell on this but have seen mention of 30 minutes. Doe sit only really work if left going for 30 mins.? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #52456 2nd Mar 2011 11:33am
dan_uk_1984
I've found it's only noticeable after its been running for the full time. 30 mins is the max it will run for.
The temp gauge on the car doesn't start at 0, so if the coolant is at 5C and the FBH heats it to 50C that's probably only enough to get it off the white line, but it means the engine is already at 50C so will warm up much quicker.
Let it run for the full 30 mins, I used to set mine to run twice a day which was great when everyone at work was scraping the ice off their cars.
I also have the remote, do you know f you have the receiver unit in the right hand storage area in the boot?
D
Post #52458 2nd Mar 2011 11:45am
comports
Hmmm. Not seen anything in there but will have another look. Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #52572 2nd Mar 2011 4:06pm
Andy
So, can I just get this right then- even though I DON'T have the remote, the FBH will still heat the interior on cold mornings? Just a case of setting it in the OBC?
I'm with the others on this- mine just blows cold. Maybe I didn't run it long enough to get the benefits.
I assume the remote just switches it on at will rather than using the OBC settings? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #53852 10th Mar 2011 12:58am
Thumbs Up ... - .- -.
Post #53861 10th Mar 2011 9:43am
