|  | Home > Technical (L322) > 4.4 TDV8 oil leak |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1432      | To select neutral remove the insert from the front cup holder unit and find a slotted head screw beneath, turn that and it should go into neutral. Note that RRs should not be towed any distance, they need to be carried on a truck or trailer, otherwise the transmission will be damaged. See more detail in handbook. Maybe also via search on here, I recall another thread not so long ago. Only Range Rovers since 1988 | ||
|  27th Dec 2019 2:30pm |
| madpugger Member Since: 07 Feb 2013 Location: Aberdeenshire Posts: 49    | Perfect thanks.
|  27th Dec 2019 3:05pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | https://www.fullfatrr.com/forum/topic54000.html
|  27th Dec 2019 3:55pm |
| madpugger Member Since: 07 Feb 2013 Location: Aberdeenshire Posts: 49    | Thanks. I got neutral no problem. It’s the turbo oil pipe I’m now trying to access... | ||
|  27th Dec 2019 4:11pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Check where the oil is coming from. If I’m not mistaken the other end of the oil feed pipe comes from the back of the engine and if it is coming from the top end of the pipe then it is an easy pipe to access and is fixed with 2 new Orings have a search there is loads on here about the fix and how to do the Orings. There is nothing that can't be fixed with a hammer😜😜
|  27th Dec 2019 5:11pm |
| madpugger Member Since: 07 Feb 2013 Location: Aberdeenshire Posts: 49    | Thanks,
|  27th Dec 2019 6:36pm |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561      | As NMJ says Worth checking the top of that pipe, and also the oil cooler generally top of the 'Vee'.
|  27th Dec 2019 6:52pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | When I say top end I mean at the back top of the engine and running down have a look here as a possible source which is a damn site easier to fix. https://www.fullfatrr.com/forum/topic35977.html?highlight=o+ring There is nothing that can't be fixed with a hammer😜😜
|  27th Dec 2019 6:55pm |
| madpugger Member Since: 07 Feb 2013 Location: Aberdeenshire Posts: 49    | Thanks guys, had a quick look at the cooler end but don't see much oil there.
|  27th Dec 2019 7:44pm |
|  27th Dec 2019 8:01pm |
| 66jag Member Since: 14 Jul 2019 Location: Lancs Posts: 4      |
 Having the same problem with mine, oil leak from area of n/s turbo, did you ever get to the bottom of the problem? The issue as you say is seeing where the oil is coming from, local garage wants to drop the engine and fit a new turbo but at £3k+ I’m not ready to fire the parts cannon... | ||
|  22nd Sep 2020 5:09pm |
| Posting Rules
