![]() | Home > Technical (L322) > Can anyone help in identifying this engine noise....VID NOW |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35823 ![]() ![]() |
upload video to you tube and place a link here.. ... - .- -.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259 ![]() ![]() ![]() |
It could be the VANOS or the chain guides/tensioner on their way out. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
easiest way to diagnose the timing chains on the bmw v8... is to drain the oil, and remove the lower sump... the gasket will come off ok.( diff guard needs to come off easiely) look in the sump tray for plastic debris. any signs, then your chain guides, have gone brittle, and broken up.. the nylon faces, clip onto the U shaped centre carrier, and self adjusting side bar. these break up, and detatch. the guide is then soft aluminium, rubbing against the chain, which is shaving off the metal. the chain will also rub against the front timing cover, as no groove to run in...further metal being removed etc. don't drive the car! that metal is going through your oil! if the chain jumps a tooth, its curtains for the engine.
200AD Member Since: 17 Apr 2019 Location: Leicestershire Posts: 18 ![]() ![]() ![]() |
Or it could be, as I found recently, down to loose spark plugs!
CHAin guides. Do as advised above |
I've managed to get the vid to run. That sounds way worse than my plugs.
