Home > Maintenance & Mods (L322) > Rated recovery points for 2004 RR L322
RSW vogue 2004
Australia 2004 Range Rover Vogue 4.4 V8 Zambezi Silver
G'day All,
I have done a search and failed to find anything about Rated Recovery Points for 2004 Range Rover. Does anyone on the forum sell them or know where I can purchase a pair for the front in particular?
Thanks for your time and hope you all have a SAFE and Very Merry Christmas.
Cheers
Post #538365 24th Dec 2019 2:02am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I am pretty sure the tow point in the centre of the car is heavily rated and good enough for a snatch. Use a receiver tongue in the rear . Always use a damper you dont want to kill yourself or others
[/img]
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #538366 24th Dec 2019 3:36am
RSW vogue 2004
According to my user manual both on and off road flat tow points only. No mention of being able to handle snatch type pressure
Post #538367 24th Dec 2019 3:48am
wayneg
Only hearsay however I used to do lots of hardcore offroading with the AULRO group and there were some very knowledgeable guys there. Some trips demanded rated recovery points for admission, P38a`s not allowed, L322s OK. I would not use the rear tow eye only as a recovery hitch is so easy to attach and is central. Have you had a look at the front tow eye, its no tie-down point. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #538368 24th Dec 2019 4:06am
RSW vogue 2004
The book states flat tow only for front ring
Post #538369 24th Dec 2019 4:13am
wayneg
My handbook states rear eye can be used in off-road recovery situations, front eye cant be used to tow caravans or trailers. I have both snatched and been snatched and winched from the front eye with no dramas but always take care and nothing to violent. Your call I think, I have seen nothing aftermarket sold or fitted only D3 bullbars that will never have compliance approval. Hard Range was tricking up a TD6 long ago, see if you can find any info from them, if anyone has done it, they would. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #538370 24th Dec 2019 5:54am
CS
The eye at the middle front seems fine, I've been pulled out when 'bellied' in the mud in my 2004 car using that. I recall the handbook warning about being pulled out from the rear as regards possible gearbox damage, you might want to check that before doing that. As I have a towbar I would attach to that at the rear, so have not needed to try anything else. Only Range Rovers since 1988
Post #538411 24th Dec 2019 2:29pm
RSW vogue 2004
G'day All,
Merry Christmas and Happy New Year, looks like we have a blank in the knowledge bank. I have made some posts in other places to find an answer.
Cheers
Post #538784 29th Dec 2019 10:25am
ebajema
Have a look at Harry's Garage on You Tube, his review of the L322 for daily use. In the clip he mentions something about the design rating of the tow points and their snatch load. He is a special adviser to JLR and the editor of Evo magazine, so I think he has some pretty good info (although I did have to correct him on something, have a look at the comments Smile). MY 2010 5.0 SC Galway green and sand interior!!
Post #538792 29th Dec 2019 11:31am
RSW vogue 2004
Thanks very much for that youtube video. According to Harry's Garage the front hook is rated at 7 tonne, so well enough for snatching and being snatched.
Thanks again for your help.
Cheers
Post #538878 30th Dec 2019 2:28am
GGDR
I also remember Clarkson talking about the rear driver's side hook being several tonnes worth....
. Cheers, Greg
Post #538886 30th Dec 2019 9:31am
RSW vogue 2004
Thanks GGDR for that information but I have the back covered with the hitch block with D shackle. Just the front was my target.
Cheers
Post #538888 30th Dec 2019 9:40am
