![]() | Home > Maintenance & Mods (L322) > Air to coil conversion |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Hi, Guys has anyone had any views on changing from air to coil suspension on a 2011 ffRR as it seems to me that more people sell their cars with the problems that are associated with the air suspension? I know that you can not change the height at the press of a button but if you need to go off-road a lot then perhaps a lift kit? What's it ride like on the black stuff?
I get where you're coming from with 2/ I bought my 1st range rover manual back in the 80s and the kids and Her indoors hated them for rolling around at roundabouts, country lanes.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
I think by the time you have paid to do the conversion you would have been able to fix an airbag or 2.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7987 ![]() ![]() ![]() |
I’m pretty sure coil springs aren’t type approved for the L322, so I’m again pretty sure your insurance would be invalid.
my concern is not the bags it`s the sensors and electrics if only they kept working it`s not as though they are a moving part like brake pads, engines, gearbox. Easten car companys can give 7 years warranty |
Not generally a problem with the ride height sensors. The main failure on the 2010> cars is the adaptive dynamics wiring, which is an easy fix with an updated LR part, plug and play. The AD sensors don’t break it’s the wires, which once you know how to mend it it’s not a big deal. certainly not worth junking the whole suspension set up for.
I am not a fan of getting away from the standard, JLR spent a lot of money and time creating the car that`s very interesting about the update as a plug and play? Is it something that I can get from Duckworths? I have replaced the wires from the adaptive suspension under the bonnet with parts from LR Duckworths.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
Have you drilled out the sintered cone filter on the compressor? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I run it without the filter in and still had the fault come back? |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Correct me if I’m wrong but the l322 headlights don’t have automatic headlight levelling as we have air suspension which ensures this. By removing this your lights don’t technically level and you are opening up mot failure.
