![]() | Home > Maintenance & Mods (L322) > Signs of coil failure in the later 4.4 and 4.2 units? |
RSW vogue 2004 Member Since: 30 Nov 2019 Location: New South Wales Posts: 11 ![]() ![]() ![]() |
G'day,
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Unnecessary quote removed
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Thanks RSW - I had that engine before and it was a lot easier to track down as you say. Moving on mine made no difference,
Not sure Dan will have a look later if I get the chance have to say apart from the od almost like a hiccup runs like a dream |
It could also be the leads they are in a harsh environment and may as they get older get too hot but then you would expect this to show up on higher revs as a fault |
