![]() | Home > Maintenance & Mods (L405) > Lazer Lamps Grille - enough interest |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2707 ![]() ![]() ![]() |
Completely agree that std lights are cack, but I’d only be interested if the design looked better than that, l know there has to be compromise but it looks a bit heath Robinson, might be different in the flesh, could there not be a solution that’s easier? Perhaps mounting where the fogs are? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Unfortunately that's Laser's way of fitting them MrTee... They sell kits for lots of the Ford commercial range |
Did you do a thread on your lightbar solution Craig? Can’t remember. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35763 ![]() ![]() |
i agree with craig that they are nor stylish at all...
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Would they not be too low to conform to Con & Use regs? Fog lights are different and, legally, should only be used in fog or falling snow. John
probably John...but i reckon the FF fogs are roughly the same height as a normal cars headlights ... ... - .- -.
LT Member Since: 13 Mar 2017 Location: South West Posts: 414 ![]() ![]() ![]() |
It's the dipped beam that's the issue for me. Don't the Lazers come on with full beam only?
Flyingfocrs Member Since: 18 Oct 2016 Location: On the croft with the horses Posts: 93 ![]() ![]() ![]() |
I have already upgraded to the Osrams and they are a definite improvement but I still want more on the full beam as I find there are dark areas and the cut off is quite pronounced.
I agree. The flush mounting in the grille is as good as it gets.
I already have a spare grille so the next option is to invest in a 3d printer and make my own mounting for the grille. |
Is there an option to have lights to fit the gaps, or is there a style of grill that allows more light through? The more gappy sort of honeycomb one might be ok? Happy to buy a crappy one for research purposes.
That is another option i’m exploring, as Craig did mount it behind the grille and then fit a more open style grille. |
if you active vents behind the grill it might restrict your choice if lights.. ... - .- -.
What are these active vents you speak of Stan? |
