Home > In Car Electronics (L322) > Sat Nav/TV Module issues 2004 Blue Plugs |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
I would suggest removing all units and getting inside to look for corrosion -- plenty of contact cleaner and a soft toothbrush maybe required! Current: 2011 FFRR Vogue SE 4.4 TDV8
2nd Jan 2020 10:45am |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 294 |
I've had a bit of a mess with it today and realised the blue sleeve comes off to reveal a normal ish connector which has some corrosion.
2nd Jan 2020 2:23pm |
I think you'll need to go further and open up the units themselves -- I would imagine you'll find corrosion inside on the boards and pins in the units! Current: 2011 FFRR Vogue SE 4.4 TDV8
2nd Jan 2020 2:29pm |
Both units are good replacements to be honest and I have tried with another spare navigation computer and TV tuner and its no different which all points towards this one plug. I have managed to get my head around the basic layout of it, if the car did not have navigation the white plug would not be in use, that is actually the video feed from the navigation as far as I can tell. Having driven it today the radio worked perfectly for the entire journey (which shows all devices plugged into ibus are currently responding) and satnav woman was still warning me of the speed cameras so that showed the nav computer was on, and aware of where we were via GPS coordinates. I was also able to change radio station using the buttons but there was just no display. As I mentioned I did manage to restore the display for a couple of seconds during my cleaning attempts which shows its a bad connection in this multiplug.
2nd Jan 2020 4:56pm |
