Home > Maintenance & Mods (L322) > Brembo brakes - will they fit?
Andy
I think I may have just wasted money on a pair of Brembo calipers from a 2008 TDV8. I wanted to fit them to my 2009 facelift but I’m told they won’t fit. Mine has the TRW calipers on.
Is this correct? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #539205 2nd Jan 2020 5:37pm
Mikey
Correct, they will not fit
You need 4 pots from a Range Rover Sport, or any 6 pot calipers from an L320/405/494 Thumbs Up
Post #539222 2nd Jan 2020 7:04pm
mjdronfield
I’m not an expert, never done any brake upgrades, but according to the thread below, which you may have read, it seems 4 pot and 6 pot Brembos have a different calliper bolt hole size, so are not easily interchangeable.
https://www.fullfatrr.com/forum/topic33462...bo+upgrade
Perhaps you needed a 6 pot set from a later car?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #539223 2nd Jan 2020 7:09pm
Andy
Funny you should say that. They sent me a pair of Sport calipers by mistake. They are being swapped next week. I may well cancel the replacements and just send these back 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #539225 2nd Jan 2020 7:16pm
Andy
I’m told the Sport calipers are the same as the L332 apart from the weights attached to them? In which chase, shouldn’t the 08 L322 ones fit or is there another difference?
Sport
L322 (what I should’ve received)
Post #539227 2nd Jan 2020 7:59pm
Mikey
The hold spacing on the L322 4 pots is smaller than the spacing on the 6 pots
The spacing of the non Brembo carriers on the facelift 2010MY is the same as the 6 pot Brembos, which is the same as that of the 4 pot Brembos fotted to the L320 Sport
Post #539252 2nd Jan 2020 11:58pm
Mikey
As per last post, the mounting holes are spaced differently
What you HAVE received are L320 4 pots, which have the same spaced mounting holes as the TRW setup currently fitted to the car
What you were EXPECTING will only fit 02-09 models
The 4 pots you HAVE will fit, but the blocks may foul the wheel/hub
The blocks may need some slight modification to fit, or, swapped with the earlier style blocks
All that said, I'm not sure of the brake disc you would use. I know the D4/RRS uses the same disc between the TRW and 4 pot setup, I assume it would be the same with the L322. But, I've never fitted a set of 4 pots to a facelift car...
Send them back and get some 6 pots Thumbs Up
Post #539254 3rd Jan 2020 12:02am
Andy
Even if they fit, they might not have the braking power equivalent to the standard brakes or the 6 pots. Not worth the risk to be honest- I’ll send them back 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #539257 3rd Jan 2020 12:31am
GraemeS
Australia
Mikey wrote:
The hole spacing on the L322 4 pots is smaller than the spacing on the 6 pots
Is the hole spacing different as well as the hole diameter? I'm aware that the bolt diameter changed from 12mm to 16mm.
Post #539259 3rd Jan 2020 12:49am
Mikey
Correct. Bigger holes and wider apart Thumbs Up
Post #539262 3rd Jan 2020 12:58am
GraemeS
Australia
Thanks Mikey.
I had considered the unlikely option of replacing my 6-pots with 4-pots to allow 18" Compomotive or similar rims so its good to know that drilling out the holes in the L322 4-pots wont make them fit. If the Pirelli AT+ was available in the D5 255/60R19 size then I'd swap to 19" D4 rims, but unfortunately no decent 19" tyres for my use are available so I'll keep using 275/55R20 AT+.
Post #539268 3rd Jan 2020 3:41am
Andy
I've returned the calipers and had a full refund. Now to find some 6 pots. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #540588 14th Jan 2020 8:38pm
