![]() | Home > Maintenance & Mods (L405) > Help Rear Seat Removal |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
Or if someone has access to topix I see there is a guide on there... Must say a really silly design that does not allow you to get under the seat in my old D4 this would have been simple.. |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
It's quite easy, surprisingly...
Thanks very much is it the same for the other side? Its down the seat in the other side, which is not a single but also the middle seat.. |
yes, similar plastic knobs! |
Thanks given it a go and cannot get them to budge.. |
You need to pull the two plastic levers (just under the rim, one is under the center piece and one under the left corner) to the left, while lifting the seat up. That's it!
Ummm will have another look, found two white plastic things I tried to pull but nothing moved |
Not white, the levers are black! |
Thanks worked it out pic help, but could not find the airpod |
