![]() | Home > Maintenance & Mods (L322) > Freeview upgrade for touchscreen TVs |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Is anyone aware of a freeview TV upgrade for FFRRs? I currently have a 56 plate Vogue SE with the touch screen TV/DVD etc, but by the end of the year the analogue TV will be non-functional in my area. I queried it at my local dealer last year and they were not aware of anything. I would have thought LandRover would have brought out an upgrade module of some sort by now. I would look for an aftermarked add-on, but that would most likely have an extra control unit, whereas I would expect LR to update the touchscreen software as part of the upgrade.
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
Guessing yours is based on the BMW system I'd say there is a solution Try NavTV or Prestige Audio in NW10 |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
I'm in the same boat, surely its just a new tuner required? The newer one used in the D3, RRS and FFRR should just fit, trouble is, finding one cheap enough! Discovery 4 HSE
Adam I am led to believe that the cables are somewhat different |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2071 ![]() ![]() ![]() |
I asked my local stealer about upgrading and was told it was not possible. But not given a reason, so suggest the cable issue, as mentioned, could be the reason. |
There's bound to be an aftermarket add-on box that can receive Freeview.
Cheers Ken. As per RRUK, I was thinking a tuner upgrade, but if that's not viable, then I was thinking that at the very worst I would be able to get a unit that sat between the existing aerial and head unit which received freeview, converted it to a UHF frequency (much like a video recorder or after market set top box) and I would tune the TV into this, the freeview channels being searched (unfortunately) via a seperate up/down scanner etc etc Steve
I may have found an alternative if LR don't do an upgrade - an addon DVB tuner kit for £210...
Looks good as I'm looking for a proper DAB solution not a highway |
Have e-mailed these guys ,sounds good, plus i noticed the night vision reverse camera , and they are only in Edinburgh 40 mins away. |
Let us know |
Yep Mick, that's the box. I was thinking of using the AV inputs on the rear of the front centre armrest, but if I remember, it ony feeds the 2 rear screens, but 2 out of 3 is better than 0 !! |
The Company sent me this reply ......
Thanks for that information Mick. If I order one I think I'll see if there's technical data supplied to allow me to self-install the kit, to save £120.
